dftf's avatar
dftf
Issues with calls and low data-speeds since joining SMARTY
Hi all
Since joining SMARTY a couple of weeks ago, I'm facing constant-issues with being unable to send or receive phone calls, and very low data-speeds (literally 1-2 Mbps up or down) at home, and around my local-area.
Just wondering if anything can be done?
CALLS ISSUE
With the calls issue, I sometimes see "mobile network not available" or "carrier connection failed", even though I appear to have a signal (and if I send myself a test SMS, it is always received back; and I can load websites, albeit very-slowly on 4G).  I have also seen "emergency calls only" on a couple of occasions.
Most of the time though, there are no errors, but when I make a call, I simply hear nothing: no dial-tone, and the call just cuts-itself-off after about 15 seconds of trying.  When people call me as a test, they also say they hear nothing, and their call also "just ends".
In my Phone app, I've checked under Settings > Calls > Call forwarding that "always forward" is set to "off".
Not sure what else I could check on my-end? ๐Ÿค”
SLOW LOCAL DATA SPEEDS
At home, I can get around 2-3 Mbps max on 4G, if I go right-up to a window; upload is around the same.
At my local shopping-centre, it varies by shop, but the highest I've recorded is 2.5 Mbps download, though in some shops as-low-as or under 1 Mbps, and upload-speeds between 0.6 - 3.7 Mbps.
Needless to say, trying to load a website is like being back on dial-up: it takes anywhere from 15-20 seconds for a site to load, though in some cases I get "DNS server unreachable" or "no Internet connection".
However, my phone is clearly not the issue, as in another retail area near me, I've got up to 87 Mbps down and 28 Mbps up on 4G.  So, clearly, there is just no signal in my local area.
This is despite SMARTY's signal-checker page (https://smarty.co.uk/coverage-checker) reporting "Yes - Excellent service" for 4G at any of the affected postcodes.  Yet I'm clearly not-getting an "excellent service".
Is there anything I can do?
I know there is a possibility of 3 (SMARTY's parent-network) and Vodafone merging next-year, but obviously depending on which masts they will each retain, that may-or-may-not help.  And it may yet not even go-through.  So... kinda feels a bit misleading to say "excellent service" if that isn't the case right-now. ๐Ÿคจ
  • TerryLo_2907975's avatar
    TerryLo_2907975
    In settings search  voLTE then turn on ๐Ÿ‘
    TerryLo_2907975
    I had this for along time ,until I went into phone settings  and turn on my VoIP , must  have turned  of when loading smarty, ๐Ÿ‘
    dftf  Replied on your other post (didn't know that you had done a Coverage check)
    What network were you with before? Was it much better?
    As you say, you did get a good signal nearby and so it is a problem with your local mast(s). This makes Network Status check more important possibly.
    • dftf's avatar
      dftf
      Hi MSF
      Yes, I did use the coverage checker page before joining.  (Not that-that helped, though! ๐Ÿ˜)
      I never had an issue with calls previously, that's only since joining SMARTY.  I wonder if something has gone-wrong during the PAC port-over process?  I do recall that while mobile-data and SMS both started working after I received the "we've ported you successfully" e-mail, my calls didn't work until the next-day.  But since then, around half-the-time I try to make an outgoing-call, I just get a totally-silent-line and nothing happens.
      Is there any-way to find-out if the Vodafone merge (if approved) would improve things?  I've looked on cellmapper.net, and it says my nearest 3 mast is 0.6 miles (0.97 km) away.  However... my nearest Vodafone one is within 0.2 miles (0.32 km) away.  But, assuming the merge did go through, is there any-guarantee that nearer mast would be kept, and used? ๐Ÿค”
      Also, on the subject of checking-before-joining, I also note that if I go on OFCOM's site (https://checker.ofcom.org.uk/en-gb/mobile-coverage) and enter my postcode, it says EE and 3 are "limited" for indoor data and voice in my area, but "likely" good for outdoors (which hasn't been my personal experience!).  Vodafone and O2 are apparently both good indoors and out.
      I've also tried this site, https://mastdata.com/resources/coverage-map.aspx , which again shows ๐ŸŸ  dots around my home, but mostly ๐ŸŸก๐ŸŸข across my local shopping-centre.  But in both places, I struggle to get more-than around 1-3 Mbps download on 4G.  So that also seems inaccurate.
      So... whose data can we actually trust to get a reliable-picture before joining a network? ๐Ÿค”๐Ÿคท๐Ÿปโ€โ™‚๏ธ
        dftf This all sounds rather unfortunate.
        Whose data can you trust? I think the proof of the pudding is in the eating i.e. if it works, then it's good.
        Possible merger? Who knows if it will help anyone-----except the shareholders.
        Sounds like you may need to revert to previous network - a shame!
