SimonCr_2335507
22-01-2024SMARTY Pioneer
Numbers being blocked
Had a few issues today . Had to contact Apple to sort out my new computer . They tried to ring me back …. First attempt went straight through to voicemail even though I was connected to WiFi calling ...
WilliamT_247204
12-02-2024SMARTY Pioneer
Hi I also have a similar issue with a called appearing to be blocked but I have not blocked it and it does not show in my blocked calls . It is important that I can receive calls on this number . Any suggestions would be greatly appreciated
- MSF23-02-2024SMARTY Guru
WilliamT_247204 Do you mean that someone says they called you, but there is no evidence of that?
Were they in the UK? Were they dialling your number correctly, from contact list, with +44 maybe?
