Do i need to have roaming switched on when I use data on Europe?
Options
โ03-04-2024 20:02 PM
Options
โ04-04-2024 10:35 AM
@Constan_2558390 Yes you do need to have it on - simply because you are actually roaming.
Options
โ03-04-2024 21:18 PM
YES, you absolutely must do that, as you will be ROAMING on networks overseas, so roaming must be switched on. If you do not switch roaming on, you will not receive emails, or be able to user the Internet on your phone.
