Voicemail issue
Emmanue_1314571
Hello,
People who call me cannot leave me a voice message; they hear "Impossible to connect your call. Please try later". It's like my voicemail is off (the support tell me it is on). Still, I think I set up it right.
Given that this has been going on for months, that chat support in India is telling me nonsense, what solution do you suggest? I'm confused and angry.
Is there an email to make a complaint?
Thanks.
12 REPLIES 12
Glider
Can you dial in to listen to voicemails?
If you can is your mailbox full and needs messages clearing?
Emmanue_1314571
Hi,
Try this:
team@smarty.co.uk
h9a446hk@smarty.intercom-mail.com
smarty.co.uk/complaints
In my case, the VM issue that had been dragging on for months was fixed in 24 hours.
Good luck.
Rebekah_150
Hey  Emmanue_1314571
I am sorry you have been having issues, It might be that you need to set up your Voicemail.
Setting up is easy, the recording will take you through each step:
1- Dial 123 from your SMARTY SIM
2- Choose a PIN
3- Select # and confirm.
4- Record your name
You can change your name recording whenever you want in your mailbox settings.
Hello, you say that "You can change your name recording whenever you want in your mailbox settings." - please can you explain step by step how to do it? I called 123 and selected option 4 to change mailbox settings but there's no option to change the name! I used the chat and was told once the voicemail is deactivated I'd then be able to set it up again from scratch after 2 hours but it didn't work. When I contacted them again they reactivated it for me but it still has the same settings that I can't change! I spoke to several advisers so far and nobody seems to be able to help with it..! Not good, Smarty...
Hello, you say that "You can change your name recording whenever you want in your mailbox settings." - please can you explain step by step how to do that? I called 123 and selected option 4 to change mailbox settings but there's no option to change the name?? It's driving me crazy and the chaps in the chat have so far been unable to help me with that, and I've spoken to several now...
I'm not sure voicemail setup works this way, if you've switched your number to SMARTY.
I wasn't able to setup my voicemail this way after switching my number to SMARTY.
Thanks for the answer, but if it was that simple, I wouldn't have asked the question here.
Have you recently ported in a number from another network? Does your phone settings show the correct number?
None of that.
Extract of the complaints answer: "I have raised this with my technical team as there seems to be an unknown error causing this".
Now it takes patience and finding a competent person to take care of the problem.
Good luck getting your issue resolved @Emmanue_1314571. Sounds like SMARTY haven't done a great job so far.
I've found online web chat support is often frustrating, and a waste of time. I've needed to get the support team supervisor, or make a complaint, just to get a service/technical issue looked into and resolved. I feel there's room for improvement.
๐Ÿ€๐Ÿคž
Have you tried the following @Emmanue_1314571?
  1. Use web chat, and ask SMARTY to TURN OFF your voicemail.
  2. Wait 2-3 days.
  3. Use web chat, and ask SMARTY to TURN ON your voicemail.
If that fails, you can request SMARTY call you back to discuss your complaint by calling 0333 338 1054.
SMARTY say they'll call you back within 3 business days.
Hello,
Thank you for your reply.
TURN OFF, TURN ON voice mail: This has been done several times without fixing the issue.
I sent a complaint which I hope will be successful.
