Virtual phone number not working
Sedona
I am experiencing an issue with calling my MoreMins virtual number. When I attempt to make a call, I receive a message stating that the call is not recognized. I have contacted MoreMins support, and they have suggested that the issue might be with my mobile operator.
 are any  issues on your end that might be preventing calls to my MoreMins virtual number? I have entered virtual phone number in call forwarding shall I leave when busy when unanswered and when unreachable in their smarty default numbers or add the virtual number in them as well, they did manage to ring me and it worked somehow though
WelshPaul
Looks like a standard mobile number and you should be able to call it using either 07520, 00447520 or +447520.
10 REPLIES 10
Rebekah_150
Hey  Sedona,
we would need to investigate this in greater details if you an please contact our customer care team they can assist you https://smarty.co.uk/contact available daily from 8am โ€“ 8pm.
Thanks Rebekah I've sent an email to customer support
@Sedona  When you say "on your end" - we are the community forum and not Smarty themselves.
I suspect that the number you are calling is not either an 01,02,03 or STANDARD 07 UK mobile number. If that is the case, you will need credit on your account to pay for such a call as they are not included in any Smarty plan.
Please check the Price Guide for charges to special numbers.
Sedona
@MSF  I put in +44 at the front of number hmmm, thing is I can receive SMS texts of which i tested ok
Cheers.
@Sedona  I took a look at their website and it seems quite complicated. It is using internet calling as far as I can see and therefore it seems logical that you would need the +44 in front of a UK number.
Sedona
I added o in with number problem solved cheers ๐Ÿ‘‹๐Ÿ˜€
WelshPaul
What are the first five digits of your virtual number?
75206. Also +44 at front of number
WelshPaul
Thanks Welshpaul !  I added the o and it's working fine now ๐Ÿ˜€๐Ÿ‘‹๐Ÿ‘
