Sedona
19-07-2024SMARTY Pioneer
Virtual phone number not working
I am experiencing an issue with calling my MoreMins virtual number. When I attempt to make a call, I receive a message stating that the call is not recognized. I have contacted MoreMins support, and ...
- 19-07-2024
Looks like a standard mobile number and you should be able to call it using either 07520, 00447520 or +447520.
Sedona
MSF I put in +44 at the front of number hmmm, thing is I can receive SMS texts of which i tested ok
Cheers.
19-07-2024SMARTY Guru
Sedona I took a look at their website and it seems quite complicated. It is using internet calling as far as I can see and therefore it seems logical that you would need the +44 in front of a UK number.
- Sedona19-07-2024SMARTY Pioneer
I added o in with number problem solved cheers 👋😀
