Sony Xperia APN help
BillTur_1797604
Hi,
Anyone here use a Sony Xperia handset?
I've tried changing the APN settings on an Xperia 5 IV as per the Smarty instructions but they are not accepted. I am assuming it's because the APN type cannot be blank as per the instruction. I can leave it as it is but I'm sure that I should be
5 REPLIES 5
WelshPaul
APN type should be: default,supl,mms,xcap
Oh thanks for that. Not sure why the Xperia instructions state it should be blank then
Also, to check, should I change the MVNO type to be 0307 instead of the default 0309?
Seems fine using the default settings tbh, but the instructions state to change them for Xperia....not sure why.
Thanks
Nope. ๐Ÿ‘
Ok thanks for that, I will leave everything as default then.
Not sure as to why Smarty are stating that it needs to be changed on Xperia phones ๐Ÿคทโ€โ™‚๏ธ
The Smarty instructions are confusing. I have a Google Pixel 6a and Smarty say to leave the APN type field blank but my phone won't allow this, but I can enter default. Smarty support weren't sure why and couldn't troubleshoot it. I will just see if it works abroad.
