So many questions!
Richard13 We are Community Forum members like you and do not actually work for Smarty. That means we have no access to your account.
If you web chat with the Support Team, you should not need tone suspicious as you will be directly in contact with Smarty.
I was basically just asking what others thought of the situation, and if anyone had experienced similar, not help with it.
- MSF11-04-2024SMARTY Guru
Richard13 It sounds like your wife's sim ws taking a while to activate from what you say here. That can happen and sometimes can take a while. As JJP2RidesAgain says, if you were trying to deal with your wife's account, it seems quite right that Smarty would want to verify your right to do that - GDPR?
Did you activate her sim on a separate account or as a 'nickname' account within a group that you manage?
- JJP2RidesAgain10-04-2024SMARTY Centurion
You want to know what others think of the situation ?
OK, youโre way overthinking this. When you talk to someone at Smarty, they of course have to verify you say who you are, to guard against ID theft and malicious use of your account.
You may have unwittingly complicated matters too - You, a male, trying to manage problems for your wife, a female. It may well have been quicker for your wife to speak to Smarty about her account herself, hence the verifying questions you encountered.
