10-26-2023 07:31 PM
Hi I have changed the settings in mobile network per your note and also enabled roaming but I still cannot connect to the network in Dubai
10-27-2023 11:17 AM
@Parndee_1932892 Your monthly money buys a Smarty plan but that can only be used in the UK or in the EU when roaming.
If you want to roam anywhere else (e.g. Dubai) then you need to add extra credit to your account to pay for all usage. Details are shown in the Price Guide https://cdn.smarty.co.uk/files/SMARTY-Price-Guide.pdf?_gl=1*1r9xn96*_ga*OTI5NTcxNTk4LjE2OTM3NDM3MTI.....
United Arab Emirates covers Dubai and that is band 3 so that will cost £1 per megabyte (NOT gigabyte) and £2.50 per minute to call or 40p for a text - in addition it's £1 per min to receive a call.
You will need to add a load of cash to your account unfortunately. Possibly best to rely on free wifi wherever you can find it.
10-27-2023 12:46 AM
Have you got any credit added on your SMARTY account @Parndee_1932892.
You can't use your plan's UK allowances to roam in Dubai.
10-27-2023 03:27 AM
Hi I have the UK £10 rolling monthly contract unlimited calls & 60g data is that not sufficient to roam in Dubai ? Do I need to purchase an add-on has well?
10-27-2023 09:37 AM
No, Dubai isn't included in roaming as it isn't in the EU. You will need cash credit to roaming and data will charge per MB
10-27-2023 03:18 AM
Hi I have a £10 monthly rolling contract direct debit
10-27-2023 11:17 AM
10-27-2023 11:41 AM
Thanks for your reply MSF it is very helpful I think you’re right just stick with WiFi 😃
