17-01-2024 06:18 AM
When I got my new SMARTY sim card, I went through the process of transferring my old phone number from my UW sim card. I received notification that the transfer had worked.
When receiving incoming calls and texts from my old UW phone number, they come through perfectly fine on my SMARTY sim card.
The issue I'm having is that when I call others or send texts from my SMARTY sim card, the call/text suggests it's coming from the original number that was attached to my SMARTY sim card, making it very difficult for two-way communication. If people try and text the number that was originally on my SMARTY sim card, I do receive everything just fine, but it would be a pain to go and change my phone number everywhere, hence why I tried to transfer my old one.
Does anyone know any possible solutions?
17-01-2024 11:23 AM
@LeahLis_2418376 You say that your phone seems to have the correct number in its settings. I'm also assuming that your account dashboard shows the correct number.
That being the case, I wonder if you have suffered a 'split port' (painful 😱). This happens when not all parts of the process go through smoothly.
This may need a web chat with the Support Team.
17-01-2024 11:57 AM
Just type "talk to a person" to avoid the bot, @LeahLis_2418376.
Community members don't have access to customer accounts, so the web chat support agents are there to assist with account problems. They're available 8am - 8pm, everyday.
31-03-2025 16:42 PM
My SIM is doing the same calls fine messages different
31-03-2025 17:56 PM
@MavisDi_3219469 Do you mean that your phone is showing the wrong number when you send messages?
If so, you need to do a Network Reset in your Settings. The phone will have 'remembered ' the first number allocated to the sim when you activated it. If you port in your old number, the phone needs a 'nudge' to change.
10-04-2024 12:43 PM
I want change to my new number
10-04-2024 17:36 PM
@Jitende_2568400 When you activate a sim, you will automatically be allocated a new, random number. You can certainly keep that number if you wish, or else you can bring in a number from your previous provider once you have a PAC code from them.
10-04-2024 12:49 PM
We would need more information - Are you trying to port your number from another network ?
17-01-2024 10:04 AM
@LeahLis_2418376 This problem does turn up quite frequently.
You need to look at your phone settings because the phone is 'remembering' the original number that was allocated to the sim when it was activated.
For an iPhone, signing out of iMessage and FaceTime, checking My Number in Settings and then logging back into iMessage and FaceTime seems to usually do the trick.
For Android, I'm not sure, but imagine that you will at least need to look at Settings for something like My Number.
Hope this helps.
17-01-2024 10:45 AM
I am on android and while the setting does exist, it shows the old UW number I want to have and the problem is still happening.
Thank you for trying!
17-01-2024 10:58 AM
Hey @LeahLis_2418376, have you tried the following steps, to fix the issue with text messages appearing to be from the original number allocated to your SMARTY SIM card?
17-01-2024 11:18 AM
None of this has worked either, thank you for trying!
17-01-2024 11:23 AM
17-01-2024 11:52 AM
Yeahh the old UW number is showing on my dashboard.
I tried using the web chat earlier but it was just a bot so I came here 😅
17-01-2024 11:57 AM
