Loss of signal every few minutes
โ08-06-2025
21:27 PM
- last edited on
โ09-06-2025
11:31 AM
by
JodieC
I've been using a smarty unlimited data sim in a 4G mifi for about 1.5 years, maybe longer. This was mostly fine until a week or so ago. I was able to stream video, get work done, etc pretty reliably. Not sure if it's related, but after some high winds locally I started losing signal every few minutes. When I do get signal it's often painfully slow. Opening a pc image is like the old dial up days of watching it appear line by line. I ordered a replacement sim, no improvement. I bought a 5G mifi. It shows variable 4G/5G signal but it's still just as unreliable. Downdetector shows no issues in my area. Smarty's post code checker claims no issues. This happens on all my devices. My phone is on a different network, but I usually connect it to the mifi when home. I have had to resort to tethering from the phone on the other network despite paying for unlimited data with Smarty. I can't find any means of talking to a human being at Smarty to get any help with this. Any advice (apart from the obvious that it's time for a new provider) would be appreciated. Thanks ๐
- Labels:
Network
โ09-06-2025 11:34 AM
Hi @TezzaBee
Thank you for reaching out to our SMARTY community forum!
I am sorry to hear about the recent changes in your network connection.
It is common that bad weather can indeed affect your connectivity as the wind speeds may have damaged the mast in your area, causing issues with your service.
Please refer to our network status checker as this will display any outages in your area:
Network status checker | SMARTY
You can also speak to our support team by following this link, please note you will be asked some questions by the bot before being transferred to an agent:
I hope this helps!
- Jodie
โ17-06-2025 15:06 PM
Hi Jodie,
Thanks for your reply.
The situation has improved since I sought advice here. I am now getting 5g consistently, without all the drop outs in the signal.
There was an issue with the post code checker on the app, it would not accept my postcode as a real post code. I managed to use it on the website instead. It said there were no issues though, when there obviously were.
Now that it's up and running properly the 5g is much better than the 4g . Hopefully that will continue and I'll continue to be a happy, long term customer.
โ08-06-2025 21:52 PM
Hello, I think I experience similar issue, I just complete loose connection about 10-15 times a day. Havenโt had any problems until few weeks ago maybe. I have managed to report it but it is painful, as you donโt really get to talk to people. I use smarty for mobile router and 3 phone sims, that all lost signal simultaneously, but I still had to go through fault finding like there would be something wrong with my device. After the first go I had a lot better experience and they recorded my problem and raised a ticket. Itโs still not fixed though. Iโm in Hastings East Sussex.
โ17-06-2025 15:07 PM
did your issue get sorted out?
