03-07-2024 18:51 PM
Is it possible to make an international collect call (reverse charge call) with SMARTY?
04-07-2024 08:27 AM
@Watermelon Pretty sure the answer is no.....unless any other member knows different.
13-07-2024 11:10 AM
@Watermelon How about asking them if they use WhatsApp (other apps are available) and then you can contact them without extra charge?
13-07-2024 00:19 AM
Hi @Watermelon 👋
Why can't you just ask them to call you and then they take on the cost (as per a 'collect call')??🤔
04-07-2024 08:27 AM
