APN settings for EU
- 13-02-2024
I've got an iPhone device running iOS 17.3, DavidCr_2353705.
When I'm in the Settings > Mobile Service section, there's an area/section with the title "THREE". Within this section there an setting option "Mobile Data Network" - looking here you see the APN value, which should be "mob.asm.net", if you intend to use mobile data while you're abroad.
Your calls and texts will work, whatever the APN value.
The following forum articles should help:
- https://community.smarty.co.uk/t5/faq/setting-up-your-android-device-to-work-abroad/ta-p/7919
- https://community.smarty.co.uk/t5/faq/setting-up-your-ios-device-to-work-abroad/ta-p/7918
As I said I used this same SIM in November in Spain without a problem but the name has since changed from "3" now saying " Smarty Internet" it's this change that I am not happy with ..why suddenly change ..I have tried it in another phone but still saying " Smarty Internet" . I know nothing is 100% when abroad using a phone . I travel a lot always been on O2 with no problem abroad and in Novber on Smarty no problem but then it said "3" ..it's this change of name I want to enquire why has it happened ..thks
Don't understand why the APN settings of a SMARTY Mobile SIM card would be labeled as "3", DavidCr_2353705.
Assuming the SIM card was supplied by SMARTY Mobile, then an APN settings label "Smarty Internet" seems logical.
Either way, whatever the label of the APN settings, a SMARTY Mobile SIM card should have an APN value "mob.asm.net" (in APN settings).
