JanetCl_2850190
03-10-2024SMARTY Pioneer
2 phones, 2 plans but plans associated with wrong phones Any ideas please
- MSFSMARTY Guru04-10-2024
JanetCl_2850190 Reply on your other post.
- SmartyTrousersSMARTY Centurion04-10-2024
You've not given us a lot of detail to go on here. If the wrong plan and number is with each phone, just swap the SIMs over.
If the phones both have the correct number, just the wrong plan, that's because you've bought the wrong plan for each SIM. I would suggest you log into the relevant Smarty account for each SIM and choose to change the plan. You will then be on the right plan from the next plan renewal date.
