Wi fi calling on Motorola g54 How to do it ?
VictorW_3121855
I am trying to activate wi fi calling on my first ever smart phone motorola g54. Just switched to Smarty but cannot open any of the articles on wi fi calling. Nor can I get into any of the settings for wi fi calling. I wonder if I need some other setting up before setting up the WI fi calling
Can anyone help please. I know nothing about smart phones.  Many thanks.... Vic
@VictorW_3121855 It will depend upon the exact phone, but you would expect to see a wifi calling button that you can toggle on somewhere within Settings> Mobile Service (admittedly that's an iPhone, but it surely cannot be far different on an Adenoid phone.
The phone will use standard mobile calling where there is some signal available  and only turn to wifi calling where there is no signal.
Decembersangel
Hi @VictorW_3121855
This is a link for a Motorola Moto G 5G Plus which shows how to enable WiFi Calling (hopefully the steps are similar).
https://deviceguides.vodafone.co.uk/motorola/moto-g-5g-plus-android-10-0/calls-and-contacts/turn-wi-...
Unfortunately your phone is NOT on the SMARTY compatible WiFi Calling list so isn't supported...
https://help.smarty.co.uk/en/articles/4237414-which-devices-are-compatible-with-wifi-calling
Hope this helps x
