Using Smarty abroad on our iPhones
MartynLe_547387
We are going to Nenagh Tipperary tomorrow and it says to make a changes to our phones now before we go.  We have iPhones. If we make the changes as suggested do we need to change them back when we are back in the UK or leave them with the new changes permanently?
2 ACCEPTED SOLUTIONS
Natalie
Hey, it is just a one off change! You won't need to change anything back when you return to the UK! - Natalie
@MartynLe_547387  Once you have made the recommended change, you will not need to make any further changes when you return.
I have tested this a number of times on my iPhone, and it is fine.
Natalie
