Smarty plan from phone to Cellular ipad
IanNico_2380514
Hi Guys so I move my sim from my Daily Android phone to my iPad.
Unfortunately when someone calls me my phone rings not my tablet.
It's as though the tablet is not a Cellular one but it is.
Can't see a tab for calling as no keypad on show.
7 REPLIES 7
@IanNico_2380514 Have you got an app for taking the calls?
The iPad needs data - in your case it will take it from wifi or from cellular data via a sim. As @WelshPaul  says, it won't act as a phone - unless you have some appropriate app.
WelshPaul
I believe @IanNico_2380514 wants to receive (and possibly make) calls made to the mobile number attached to the SMARTY SIM when it has been inserted into their iPad. You cannot do this; the Apple iPad isn't and can't be used as a mobile phone. No app will allow this.
Thank you Paul
@WelshPaul  What about FaceTime? (Admittedly not all calls can be made though).
Also found a few that may be candidates after a Google search.
WelshPaul
FaceTime, yes. I mentioned this in my post below. Traditional mobile calls in and out, no.
WelshPaul
You cannot use an iPad as a cellular phone. It does support data, iMessage and Facetime though!
Rebekah_150
Hi IanNico_2380514
I recommend contacting Apple for device support.
