Smarty network access point settings
Like I said both Smarty SIMs are working fine in other phones there is no problem with signal in my area, our whole household are on smarty.
The problem is there are no Smarty/ 3 network settings available on the phone I've purchased Nokia 2660 and I need to add them manually. I just need to know what they are. thanks
- MSF30-05-2024SMARTY Guru
Rose_2015722 But, if the phone cannot even detect the Three/Smarty network, I don't see how you can enter settings?
Just wondering if the phone is so old that it will not pick up the frequency that Three runs on? Others who are more 'techie' may jump in with more info.
- JJP2RidesAgain30-05-2024SMARTY Centurion
Yes. MSF You hit the nail on the head in the second paragraph. As the 2600 is not picking up the three network, it’s not compatible with three. Looks like it’s an old 2G handset, so won’t pick up three / smarty, as of course, three never had a 2G network.
