Significant delay in voice calling - both on wifi and without.
I also have this issue intermittently and normally only when I call fixed lines. It's very random even in the same areas with very good 4G coverage. It's really annoying and I am suprised there aren't more complaints about this as even seems to occur with latest devices. Maybe not many people call fixed lines, but I am having this issue on/off for the last year. This issue does not happen on 3G but with the switch off just around the corner - then my experience is only going to get worse. I thought over time this would be fixed but since it's been a year already, it's not looking likely.
- MSF02-09-2024SMARTY Guru
Frank121 You mention that this only occurs when you call landline numbers. Do you know if they are internet based numbers?
It sounds rather like the issue may be at the interface where mobile moves to landline. That said, I make all calls via my mobile these days and do not experience that problem on 4G/5G.
