Setting up phone for use abroad
โ20-04-2023 20:41 PM
Hoping someone can help. Smarty state that you need to do a 'one off' change to your Mobile Data Settings to use the phone abroad. They say to change both Mobile Data APN and MMS APN to: mob.asm.net.... However it clearly isn't possible to do both with an iPhone... you can enter the details for both, but it will only set one (either Mobile Data APN or MMS APN to the new link... if you try to alter the other one, it just switches the setting... Anyone know how to rectify this or if/how the phone will still work abroad? Thank you.
โ20-06-2023 13:05 PM
Hi, I am having the same problem, spent all morning chatting to 2 difference people trying different things to solve it but nothing works, can I ask, did you manage to sort yours out & if so how ? Have you been abroad yet & did it work with just mob.ask.net in one ? Am I right in thinking as long as itโs in the Data APN bit then it should work ?
โ20-06-2023 13:26 PM
@SusanCl_2028632 My phone has Mobile Data APN set to mob.asm.net and no username or password and it has worked in EU on more than one occasion.
MMS APN is three.co.uk and other info as per help document.
โ20-06-2023 13:41 PM
Thatโs brilliant, thank you for your reply, I feel more confident that it will work now, knowing your settings are the same as mine.
spent all morning messaging 2 different Smarty people who got me trying lots of different things Ie. Resetting my phone etc etc but nothing would work to keep both Mobile Data APN & MMS APN with mob.asm.net in ๐คทโโ๏ธ as soon as I pressed reset only one would stayed.
โ20-06-2023 13:45 PM
@SusanCl_2028632 Glad that's sorted then. From memory, I have had service without problem in Spain (incl. Canaries) and France. I don't know about data speeds, but I haven't been aware of not being able to at least find what I needed.
โ20-04-2023 20:53 PM
iPhone user here and I have no problem setting the above URL for mobile data and MMS.
โ
โ12-05-2023 16:03 PM
Do I have to fill in the details ie username etc to get this to work?
โ12-05-2023 16:22 PM
@Elizabe_1222606 No, you can leave username and password blank in both mobile data and mms sections (for an iPhone)
โ12-05-2023 16:31 PM
Thanks
โ20-04-2023 21:12 PM
Interesting... my iPhone 100% won't allow both (so it switches between the two permissions)... I'll contact them via WebChat tomorrow for assistance. Thank you for the response.
โ20-04-2023 21:37 PM
Are you planning on sending multimedia messages from abroad? If not, just fill out the mobile data APN.
