Roaming - issues setting up Android
Thank you for all your input, it's really appreciated and it makes me hopeful that there's a solution on the horizon.
Doogee is one of those cheap no-name Chinese android phones, it's a rugged brick with 6000mAh battery that I carried as a backup with me - while it is 4G capable, I'm disregarding it in this experiment. I'm doing everything on Pixel 6 Pro now just to be sure.
I rejigged that APN Type field π
I noticed that in my old texts I've got 20+ welcome messages from a network called SMART. These must've been instances when my old (now deceased) Pixel 4XL connected and registered on this network automatically. Maybe that's how I was able to receive text messages in the past (I checked and I've got a bunch of NHS appointment reminders, dentist stuff etc. during the period when I was already in Cambodia, so it must've worked in the past). I'll try to drive around and see if I can find that network on the Pixel 6.
Whenever you are roaming abroad, the network you roam on sends you βwelcome to x networkβ text messages, as does your home mobile network in your home country, which basically both tell you the costs of their services in the country you have just arrived in.
- Strandloper12-09-2023SMARTY Motivator
That's a good way of hopefully ruling one of them out. Hope you find out without too much difficulty with what you know
- JJP212-09-2023SMARTY Pro-coach
Quite possibly - From googling, it appears that β Smart β is the best network, offering the most coverage, in Cambodia, with β Metfone β the next best.
- seb1112-09-2023SMARTY Enquirer
Yeah, I know that - I'm gonna treat it as an indicator that this particular network might be compatible with SMARTY'S roaming agreements, since the phone managed to connect to it in the past. I'll try to find and connect to it again and see if text messages are going through. Maybe it's not a config issue - maybe it's a network availability issue.
