Katheri_2636764
16-04-2024SMARTY Maverick
PC hotspot not connecting asking for network security key
- 18-04-2024
Thankyou for links still same response.
Have dual SIM so will try over having removed other SIM. As both give same hotspot password so could be the issue. Will update once resolved. Appreciate your support
JJP2RidesAgain
17-04-2024SMARTY Centurion
By the way, in addition to what Chalkychap @advised, a network security key is more commonly known as a WiFi password.
The WiFi password for your device is probably to be found on a sticker on the base or back of your device.
