โ21-02-2023 20:42 PM
Hello how do I enter pac code in iPhone
โ22-02-2023 14:03 PM
Do you mean your phone number is not the one you expect @DenizSi_1882857?
In your iPhone's: Settings > Phone - My Number
โ21-02-2023 23:51 PM
Same on Android and Web - PAC code option not showing under account settings?
I have a group and I can't see them under the group owner account either - think they have a bug?
Seems like other people had the same issue and customer service had to do it manually for them?
The option was there before I activated the SIM though?
Hi @DenizSi_1882857 @BistoSmart
Thanks for getting in touch.
Currently, you are only able to submit your PAC code via an internet browser. Our Mobile App does not have this feature available at the moment.
Please head to https://smarty.co.uk/dashboard/settings/phone-number, sign in and you will be able to enter your PAC/STAC code.
Hope this helps!
Best wishes,
Louis
SMARTY
โ22-02-2023 14:10 PM
Still not available in the browser. Been though this with support this morning - sent screen caps of the options I see and there is no "My number" option on the member accounts in the browser window. The "owner" account has the option to enter a PAC code, but does not show the other numbers to allow me to select them. There is obviously an issue with the way some accounts have been built? I need to get the PAC code applied manually apparently! Let's hope you don't mess it up and lose the number I have had for 20 years! ๐
