NigelAug_194872
19-02-2024SMARTY Pioneer
Re: [Network Issue] Service Update - Resolved
Hi..I am not receiving any incoming voice calls on my iphone. No calls go to voicemail but voice calls can be made outgoing. Only calls over WiFi fully work. I've checked call forwarding but it's not an option that you can open (it doesn't load up.when selected). Attached is the error message I receive when I check the status
Replies have been turned off for this discussion
- Niranja_1302464SMARTY Pioneer23-01-2025
I had a same problem with both my numbers and there is No customers service
- MSFSMARTY Guru24-01-2025
Niranja_1302464 There is - it is via web chat
- NigelAug_194872SMARTY Pioneer19-02-2024
Thanks MSF . I'll try that
- MSFSMARTY Guru19-02-2024
NigelAug_194872 Have you checked this out with Support Team via web chat? If it were just your phone playing up, wouldn't you expect calls to go to voicemail?
