โ03-03-2024 08:16 AM
Unable to find the apn settings on my phone. Tried following the info on this site but stop at the first part as I don't have an option to change my apn. Any help. Thanks.
โ03-03-2024 15:28 PM
Got it brilliant, thanks a lot.
โ03-03-2024 09:49 AM
@ChrisRo_2027341 a quick internet search revealed this, which hopefully will help: https://www.helpforsmartphone.com/public/en/oneplus/7/android-9-0/guides/22/Set-up-Internet-OnePlus-...
โ03-03-2024 18:04 PM
@ChrisRo_2027341 De nada !!
