โ03-05-2023 18:18 PM
Have come to france and canโt get a wifi connection with smarty sim in wifi device - I have enabled data roaming and have 12gb available abroad
โ03-05-2023 19:16 PM
@SusanMc_1548123 Have you checked that the settings are correct? APN needs to be set to mob.asm.net via the router home page.
โ03-05-2023 19:18 PM
โ06-05-2023 16:31 PM
This resolved the issue - thank you
