05-03-2023 06:18 PM
Have come to france and can’t get a wifi connection with smarty sim in wifi device - I have enabled data roaming and have 12gb available abroad
05-03-2023 07:16 PM
@SusanMc_1548123 Have you checked that the settings are correct? APN needs to be set to mob.asm.net via the router home page.
05-03-2023 07:18 PM
05-03-2023 07:16 PM
05-03-2023 07:18 PM
05-06-2023 04:31 PM
This resolved the issue - thank you
