Rgn
14-03-2023SMARTY Pioneer
Keep ny no
14-03-2023SMARTY Guru
If you are coming TO Smarty, then follow advice from Chalkychap .
If you want to LEAVE smarty and transfer your number to another network, you will need a PAC code to give to the new network so that they can start the transfer in. In that case see :https://smarty.co.uk/dashboard/settings/manage-plan (bottom item)
