How to set up Smarty with an unlocked Smart 4G Hub
JohnSad_3305211
Hi, I bought a Smarty 40 GB Sim (now ugrgaded to 80 GB) to use in an unlocked Smart 4G Hub. Although I can connect to my laptop usiing Wifi with my Smarty SIM in the router Wifi I am confused as to what SIM I need to put in my existing phone which was used with my previous Virgin Broadband.
1 REPLY 1
@JohnSad_3305211 You would need another sim for your phone because you cannot have two sims with the same number. This would mean you buying another one with a further plan. To save money, you could set up a group on the existing sim and make the new sim a 'nickname' sim. You would get 10% discount on each plan in the group. See the articles on Groups.
