How do I upgrade to 60GB for £10 plan? (From 30GB for £10 plan)
- 17-02-2023
I think it goes on to say if you're an eligible existing customer, you need to use their online web chat to upgrade - good luck @fuzzy.
Actually no, looks like that's not right! The 60Gb for £10 plan is available for existing users (if I've read the following correctly)...
4. To be eligible for this Promotion, you must:
a. be resident in the UK and over 16 years old;
b. be a new/existing SMARTY customer who accesses the SMARTY website or is on the 30GB plan (the“Eligible plan”)
It's from "https://cdn.smarty.co.uk/files/smarty-promo-12Mth30GBDDFeb23.pdf"
regards, fuzzy
I think it goes on to say if you're an eligible existing customer, you need to use their online web chat to upgrade - good luck fuzzy.
- fuzzy18-02-2023SMARTY Teamster
Yes, but it seems, at least to me, somewhat over complex. I mean the dashboard displays a link "Change plan >" which takes me to a page displaying other plans I can change to (at next reset). I don't understand why it doesn't just include the "60GB for £10"plan on that page? As it is, it displays no £10 plan on that page! Smarty promotes itself as simple, and it is, but could be more simple, imo.
Anyway, thanks for your help, fuzzy.
P.S. The cynic in me suggests Smarty doesn't want to make it easy for their current users to change to the more generous offer.
