โ08-03-2023
21:37 PM
- last edited on
โ28-06-2023
11:42 AM
by
Rebekah_150
What are the rules around roaming, especially in Spain (main land)? Currently on 100GB SIM.
Thanks
- Labels:
Roaming
โ08-03-2023 21:46 PM
You can use your SMARTY plan's allowances while roaming in Spain @AndrewSu_936885.
The only restriction being your mobile data allowance is limited to 12GB while roaming in the EU.
There's more information in the online help article at:
Roaming and international | SMARTY Help Centre
โ30-07-2024 09:40 AM
Could @AndrewSu_936885 have used an EU data pass and been able to use their full 100GB?
โ30-07-2024 12:38 PM
@Badger You can use 12Gb initially and then purchase a one day or three day Data Roaming Pas to use whatever is left.
N.B. you can only use up to the standard amount of data on that plan - if you have special offer e.g. 150Gb for the normal price of 100Gb, then you could only roam up to the 100Gb limit.
โ31-07-2024 15:35 PM
Thanks.
I've since done some digging as was able to confirm things. So as you have said, buying the EU Data Pass gives you access to what ever data you have left on your plan. So in my case I have an unlimited plan, so once the 12GB is used up (YouTube + child + several days) I buy a 3 days EU Data Pass and I get 3 days unlimited data in EU, which is actually ok.
I was able to speak to a support agent and they also confirmed, so I'm confident the 3 day EU Data Pass on an unlimited plan gives unlimited data. Thankfully the 12GB was only a few days short of the holiday ๐
โ31-07-2024 15:52 PM
@Badger Thanks for this - I have seen the response you received on your other thread.
โ15-04-2023 09:44 AM
I am using SMARTY for the first time abroad and finding the EU roaming is fairly hopeless, only getting 3G irrespective of which network I log onto. Whereas in exactly the same location, my wife on giffgaff is getting a stunning 5G service. Think Iโll be going back to Giffgaff.
โ04-07-2023 11:18 AM
Yes, I was on Giffgaff, but don't forget, there is a maximum of 5GB use. After that it will cost you a small fortune. Better 3G with 12GB, than 5G with only 5GB allowance. Think about it.
โ17-04-2023 06:51 AM
Im in Germany. Can only get E service (across all networks) itโs unusable. Friend with me us on Tescos network and working nicely. Awful experience and wish id not bothered. Will be going back to Voxi when i land!
โ16-04-2023 11:43 AM
Not sure if you happen to be in Espaรฑa, but Giffgaff is a subsidiary of Telefonica who also happen to own Movistar - the biggest network there. Maybe this accounts for better service level there?
