Download speed useless
- 27-08-2023
im in the exact same situation though i believe it may be the service itself as my phone using ee's network gets better connection than using my sim card router with a smarty sim. I have checked my router settings and looked at the rssi, (signal strength from the cell tower) and rssq (signal quality from the cell tower) and I'm getting good values from it. I am likely going to switch to an unlimited EE sim only plan as it is not much more expensive than a smarty plan and I'm sure it will work much better than smarty does
This might not be relevant now JohneMoon, but SMARTY terms & conditions do state their unlimited plans should not be used as a long-term alternative to fixed line broadband - currently covered in sections 5.15 and 5.16 of the terms.
Vodafone's no frills VOXI MVNO may not have a similar prohibition.
- JohnComi_34272628-08-2023SMARTY Maverick
So Smarty SIM should not be used in a router? That’s pretty much what this means..you should be more obvious about this in your marketing
- JJP228-08-2023SMARTY Pro-coach
“We” are Smarty Users, just like you !
As we don’t work for Smarty, we obviously have no control over their marketing !
It’s up to the individual user to do thorough research, rather than having a dig at other customers in the much mistaken belief that we work for Smarty !
If you do move on from Smarty, do some proper research next time and dont have a go at other customers who try to help !
