MartinH_1764359's avatar
MartinH_1764359
Solved
Data roaming in EU complaint
I have been checking my data useage religiously since last Sunday. Yesterday I had used 1.8 gb of data .. the today driving across spain i had a problem connecting so i selected a different network f...
  • George's avatar
    30-06-2023
    Hi MartinH_1764359 When roaming in the EU SMARTY only has an agreement with the networks you use/ I would expect something like what MSF has stated would be correct - depending on your device you can check what has used your data when roaming. Another top tip would be to downlaod maps over WiFi before you head off on your journey, this saves a ton of data.
