ELIZABET_125933
04-10-2023SMARTY Rookie
Data problems
I am getting no internet connection but my dashboard says I have plenty of data. I need connection for my work.
06-10-2023SMARTY Trendsetter
Perhaps there's a network fault at your location, or your SIM is damaged or faulty ELIZABET_125933.
You can check the current network status online at:
https://www.three.co.uk/support/network_and_coverage/network_support
