MartinM_1960762
27-04-2023SMARTY Pioneer
PAC code input - you must use Upper case
Had all sorts of hassle getting my PAC code to be accepted, the chat was hopeless, he kept saying enter the number with 07xxx xxxxxx but the page insists the "0" is removed.
Anyway, PAC codes have Upper Case letters, like most people i just entered lower case and it refuses it because the code is set to accept Upper Case only.
Can I suggest that Smarty either change the code to accept lower case inputs or insert a reminder to use Upper Case letters
- MSFSMARTY Guru27-04-2023
Thanks for pointing that out MartinM_1960762 - really useful info.
BUT...if they gave you the code with upper case letters, was there a reason why you did not try it exactly that way when lower case didn't work?
- YulianKSMARTY Community Manager27-04-2023
Thank you for your sharing MartinM_1960762 , I'll pass it on to our tech.
