Danielh_2828230's avatar
Danielh_2828230
No upload speed 4g ee mini hub
Hi I've just got an unlimited data sim from smarty and activated my sim.
I've put it in my 4g ee mini router and on my phone speed test I'm getting 10mb/s download speed but no upload speed?
On my tv I'm only getting 1mb download speed?
Is there any settings I need to change on my router?
Thanks
    Danielh_2828230 Forgive me if I sound dumb here. The phone speed test - are you using wifi from the mini router? How are you measuring download speed on the TV?
    • Danielh_2828230's avatar
      Danielh_2828230
      Hi,
      Yes the phone is connected to the mini hub for the speed test but fails when it tries the upload section.
      On the tv test it is connected to the wifi using my nvidia shield and I am getting 1mb download speeds
        Danielh_2828230  Can you try a speed test when the phone is using mobile data? This will indicate if perhaps the Smarty/3 signal is not strong in your area or perhaps not stable.
        This is one of the reasons why Smarty suggest not trying to use mobile data to replace home broadband.
