WayneBr_2433898
19-01-2024SMARTY Pioneer
Data Only SIM Card is an LTE or WCDMA card?
I have just activated my new Data Only SIM card for use in my tp-link “Archer MR400” LTE Router. The LED’s for the Power & Wi-Fi have lit up but not the Internet. Question: Verify that this Data On...
19-01-2024SMARTY Guru
WayneBr_2433898 The direct answer to your question is above my skill-set, but here goes anyway......Did you change the APN setting to mob.asm.net?
I must say, I didn't realise that there was any difference in SIM cards from Smarty.
