04-07-2024 22:54 PM
The coverage for 3 in my area says I can get Excellent 4G but no speed is suggested. I set up my TP-Link Archer MR600 using the basic Smarty plan but can only manage 2-9mb. Are there certain answers to the setup questions which I have no knowledge of like APN's etc, My router is in a good position and I get 75% reception shown on the router.
05-07-2024 08:54 AM
@AndrewW_2755190 If your router is getting data then that suggests that the APN setting is fine.
Have you tried moving the router nearer to a window and away from any possible metal sources e.g. RSJ beams in the ceiling?
