01-10-2024
09:19 AM
- last edited on
01-10-2024
12:44 PM
by
JodieC
01-10-2024 10:19 AM
@MeganLo_1822922 In addition to @MSF's questions, what makes and models of phones are you and your husband using?
01-10-2024 10:54 AM
Hi so mine has now been sorted and I can receive calls. (No idea how) My husbands has not both of our phones are iphones. We have reset the network we have turned off our phone etc.
Our numbers have been moved over correctly because I can make phone calls and it comes up with the correct number. I can now receive calls but my husband cannot receive calls but he can make calls again coming up with the correct number that has been changed over from EE.
01-10-2024 11:04 AM
Ok, there should be no issues with compatibility with Smarty's network if you're both on iPhones.
Did both you and your husband receive a text from Smarty saying the number transfer was complete (note that I'm asking specifically if you both received that text, rather than whether the correct number shows when you make a call)?
01-10-2024 09:38 AM
@MeganLo_1822922 Not really enough info here for a definitive response.
You ported your numbers across from EE? Do your Smarty Account Dashboards show the numbers correctly? How long ago?
There is a possibility of a 'split port' but it is unusual to see this on both phones I would think. If they were contacting EE, I doubt they would get much response over the weekend.
Have you tried a network reset on your phones?
If you are not getting a response, I suggest raising a Complaint via the website.
