All calls out result in engaged tone (beep....beep...beep) after a longish silent delay.
- 19-09-2024
I used to have that router, and I recall that for voice calls it would drop down to 3G (I don't think it supports VoLTE - voice calls over 4G).
Three (Smarty's parent network) are this week switching off most of their 3G coverage, and I suspect that has now happened in your area, meaning going forward, only a device that supports VoLTE is going to be able to make and receive calls on Three's network.
The other networks have also either already turned off 3G or are in the process of doing so, but in the case of networks other than Three, they also have 2G coverage still available, which I think the Huawei would be able to drop down to for calls.
- 19-09-2024
One thing to be mindful of is that even a router that supports VoLTE may not be compatible with the VoLTE on Smarty's/Three's network, due to the sightly different ways different mobile device manufacturers and different mobile network equipment manufacturers implement VoLTE.
Technically, I don't think Smarty 'support' (i.e. make any promises it will work) making and receiving calls from routers on their network, but as long as you buy a device which is returnable, you should be able to test it out on Smarty anyway, then either return it or test it on one on the other networks if it doesn't work on Smarty.
If you do test a VoLTE device, try some long calls (say over 30 mins, both incoming and outgoing) as issues I've read about with VoLTE compatibility include calls only working in one direction, or calls disconnecting after a period of time.
Okay. I have a (as yet unused Nothing) smart phone that I have now used (with the sim from the modem) to make a call I needed to make. Am now thinking whether to use that and learn about Tethering or go for a new modem with the caveats you mention. Life seems to be getting more complicated as the years go by :-(.
Thanks again for taking the time to coney very helpful information. Best regards, fuzzy.
