fuzzy's avatar
fuzzy
SMARTY Teamster
19-09-2024
Solved
All calls out result in engaged tone (beep....beep...beep) after a longish silent delay.
As in the title, any call I make starts with longish silent delay before I get beep...beep...beep.  Don't know if I can receive calls[1]. I can send and receive SMS (at least I just sent one to mysel...
  • SmartyTrousers's avatar
    19-09-2024
    I used to have that router, and I recall that for voice calls it would drop down to 3G (I don't think it supports VoLTE - voice calls over 4G).
    Three (Smarty's parent network) are this week switching off most of their 3G coverage, and I suspect that has now happened in your area, meaning going forward, only a device that supports VoLTE is going to be able to make and receive calls on Three's network.
    The other networks have also either already turned off 3G or are in the process of doing so, but in the case of networks other than Three, they also have 2G coverage still available, which I think the Huawei would be able to drop down to for calls.
    19-09-2024
    One thing to be mindful of is that even a router that supports VoLTE may not be compatible with the VoLTE on Smarty's/Three's network, due to the sightly different ways different mobile device manufacturers and different mobile network equipment manufacturers implement VoLTE.
    Technically, I don't think Smarty 'support' (i.e. make any promises it will work) making and receiving calls from routers on their network, but as long as you buy a device which is returnable, you should be able to test it out on Smarty anyway, then either return it or test it on one on the other networks if it doesn't work on Smarty.
    If you do test a VoLTE device, try some long calls (say over 30 mins, both incoming and outgoing) as issues I've read about with VoLTE compatibility include calls only working in one direction, or calls disconnecting after a period of time.
