BrianAb_2142196
01-07-2023SMARTY Pioneer
Using phone and texting. I don't seem to be able to do either.
1 Reply
- MSFSMARTY Guru02-07-2023
Hello BrianAb_2142196 . first thing to check is your dashboard. Is there an active sim with a phone number? Does it show an active Smarty plan?
If the answer to above is 'yes', check for local network status: https://smarty.co.uk/network-status-checker
This will show up any local mast issues.
