JanHines1957's avatar
JanHines1957
Solved
Transfer problem
I’ve recently switched to Smarty and transferred my number using a PAC. Since then, my contacts have been telling me that they’re receiving my texts from a different number. I also, eventually had a call off the NHS who had been trying to get hold of me and said that they had been unable to get through and their call was answered by someone else who gave them abuse! I’m the only one to access my phone! Help
  • Chalkychap's avatar
    Okay JanHines1957, if you're still not receiving any calls on the number you wanted to keep, it could be a split-port. The SMARTY switching team would need to rectify this problem.
    Have you contacted SMARTY customer service about this, JanHines1957?
    The advisors work 8am - 8pm 7-days a week - get in-touch at https://smarty.co.uk/contact.
    Have you tried a NETWORK RESET, JanHines1957?
    This often fixes this issue and the process will be explained in your handset user guide.
    • JanHines1957's avatar
      JanHines1957
      Hi, I have now and still have the same issue
