Odd wifi calling issue?
Hi @BobbyT
Hmmmm
If your wife has the capability to use the 'LTE' (VoLTE) network to make/receive calls then WiFi Calling 'should' work as the software enables use of both.
I know these are probably a stupid questions (and if there is a stupid question to ask I will ask it
1) Does the phone have the 'Wi-Fi Calling' app installed and is it Enabled? (under Settings search for Wi-Fi Calling as mine doesn't show up under 'Apps' )
2) Have you tried swapping the SIMS to see if that is the problem?
3) Have you tried manually updating the software to ensure the most current version is on the handset?
4) When you swipe down from the top of the screen (you may have to swipe down twice depending on the organisation) does it show the WiFi Calling icon and is it on?
5) Have you tried....
Step 1. Open the Phone app and then tap the More options icon (the three vertical dots).
Step 2. Select Settings.
Step 3. Find and tap the switch to enable Wi-Fi calling.
Other than that ....... *shrug*
I hope you find the answer but if not Google is your friend (other search engines are available
Good luck and if you think I can help you further then please let me know!! x x
- BobbyT11-08-2024SMARTY Maverick
You're a star @Decembersangel thank you for your time, I'll try these steps
Bob xx
