Need help with number transfer.
- 17-01-2024
LeahLis_2418376 You say that your phone seems to have the correct number in its settings. I'm also assuming that your account dashboard shows the correct number.
That being the case, I wonder if you have suffered a 'split port' (painful 😱). This happens when not all parts of the process go through smoothly.
This may need a web chat with the Support Team.
- 17-01-2024
Just type "talk to a person" to avoid the bot, LeahLis_2418376.
Community members don't have access to customer accounts, so the web chat support agents are there to assist with account problems. They're available 8am - 8pm, everyday.
LeahLis_2418376 This problem does turn up quite frequently.
You need to look at your phone settings because the phone is 'remembering' the original number that was allocated to the sim when it was activated.
For an iPhone, signing out of iMessage and FaceTime, checking My Number in Settings and then logging back into iMessage and FaceTime seems to usually do the trick.
For Android, I'm not sure, but imagine that you will at least need to look at Settings for something like My Number.
Hope this helps.
- LeahLis_241837617-01-2024SMARTY Pioneer
I am on android and while the setting does exist, it shows the old UW number I want to have and the problem is still happening.
Thank you for trying!
- Chalkychap17-01-2024SMARTY Trendsetter
Hey LeahLis_2418376, have you tried the following steps, to fix the issue with text messages appearing to be from the original number allocated to your SMARTY SIM card?
- Turn OFF RCS chats (“Chat features”) in the Google Messages app.
- Turn OFF the handset and carefully remove the SIM card.
- Check the SIM card is clean and undamaged, before re-inserting the SIM card.
- Turn ON the handset.
- Turn ON RCS chats.
None of this has worked either, thank you for trying!
