iD Mobile or SMARTY...... Call quality using their 4G/VoLTE network??
Thanks MSF and Rebekah_150 👍
So, all in all it won't matter (apart from £) if I am with SMARTY or iD Mobile to ensure I get a good quality phone call connection due to them both using the THREE masts?!? 🙄
MSF How is your VoLTE connection? Have you had any problems? 🤔 I'm asking as I trust your opinion with using the SMARTY network and also because a few iD Community members have also raised the same problem I am having (so you may be correct in your reply).
Decembersangel Generally, I have always had a pretty good connection with Smarty. Naturally, that may be down to the area I live in. I'm not a huge data user, so I never really bother checking speeds - pretty much all my downloads are over broadband. My phone is a newer iPhone and so compatible.
You have hit the main problem squarely on the head - it's one that many whingers people who don't get top coverage and speed for their very low price seem to not appreciate. The signal won't be great for everybody and so it is "speak as you find". People need to accept that sometimes their area doesn't have great signal quality and it may be better with another network (or maybe none!)
