PaulFag_1982936
08-05-2023SMARTY Rookie
I topped up but no calls
08-05-2023SMARTY Guru
Hello PaulFag_1982936 . When you say 'topped up', do you mean you added credit to your account? Have you actually purchased a Smarty plan? Does it show as active on your dashboard?
If you are in the UK, you will need an active Smarty plan to make calls.
