PaulFag_1982936's avatar
PaulFag_1982936
I topped up but no calls
1 Reply
    Hello PaulFag_1982936 . When you say 'topped up', do you mean you added credit to your account? Have you actually purchased a Smarty plan? Does it show as active on your dashboard?
    If you are in the UK, you will need an active Smarty plan to make calls.
