DavidFr_2847745's avatar
DavidFr_2847745
Solved
HELP - Number not ported correctly
I am getting desperate. I switched from Vodafone to Smarty about 8 weeks ago and ported my number using the PAC code Vodafone gave me. Since then I have been able to receive some calls but not others. However the most important factors are the following.
I don't seem to receive SMS. I certainty haven't been able to receive vital 2fa verification texts from the following:
My bank!, eBay, life360, X.
My elderly father has been blocked from calling me and texting me.
I have had a weekend of back and forth with customer services where I have been told to restart my device several times which has not made any difference.
I can make calls and receive some but these vital lines of communication are closed at the moment and I am getting desperate.
    DavidFr_2847745  Then it's the complaint as I suggested, I think.
  • Reagh_an's avatar
    Reagh_an
    Did you ever get this all sorted or did you switch to another provider? I've only been with Smarty for a week and I'm thinking of going back to my old provider.
    • Linsey's avatar
      Linsey
      12-05-2025
      Hey @Reagh_an
      Are you experiencing porting issues?
      • Reagh_an's avatar
        Reagh_an
        Hey, @Linsey I don't know - am I?
        The number ported fine; I simply CANNOT RECEIVE two-factor verification code text messages from my bank. I've already spoken with the bank this afternoon. They still have my original number showing up when I call them - so it has ported fine.
  • Rimal's avatar
    Rimal
    SMARTY Enquirer
    15-09-2024
    I feel for you - It's nearly 3 weeks since my port was supposed to occur yet i can't make calls / sms  and don't receive them.
    All i get from the useless customer service is try to restart my phone or try in another phone.
    They refuse to listen that the problem is at their end.
    • Reagh_an's avatar
      Reagh_an
      Have you had resolutions to your problems, yet?
      @Rimal  I have replied on your other post. You may indeed be suffering a split port if things are not working (and it may not be all Smarty's fault either!)
  • WelshPaul's avatar
    WelshPaul
    09-09-2024
    This is likely the result of a split port. First, you need to identify what network people who have issues calling you are with.
    @DavidFr_2847745 Hard too say exactly the nature of the problem.
    If you are not getting sufficient help via the web chat, then perhaps raise it as a complaint as this will reach further up the 'food chain' in Smarty. Just wondering if there is an element of a split port involved.
    Can't see why your father would be blocked from calling you - perhaps he needs to have your number removed from contacts and then put back in afresh. Also check that he has not accidentally put you in as a blocked contact.
    • DavidFr_2847745's avatar
      DavidFr_2847745
      We've tried all that. The trouble is my family mainly use WhatsApp to contact each other so the problem didn't come to light till recently. I then discovered that another person couldn't call me. Some can some can't. The biggest problem is the verification messages that are part of 2fa. none of then come through.
        DavidFr_2847745
        Also, I can ring my dad. He just can't ring me.
