AndrewSu_936885
08-03-2023SMARTY Pioneer
EU Roaming
What are the rules around roaming, especially in Spain (main land)? Currently on 100GB SIM.
Thanks
- 08-03-2023
You can use your SMARTY plan's allowances while roaming in Spain AndrewSu_936885.
The only restriction being your mobile data allowance is limited to 12GB while roaming in the EU.
There's more information in the online help article at:
Roaming and international | SMARTY Help Centre
MarkDav_1795153
15-04-2023SMARTY Maverick
I am using SMARTY for the first time abroad and finding the EU roaming is fairly hopeless, only getting 3G irrespective of which network I log onto. Whereas in exactly the same location, my wife on giffgaff is getting a stunning 5G service. Think I’ll be going back to Giffgaff.
LuisSai_1757917
04-07-2023SMARTY Pioneer
Yes, I was on Giffgaff, but don't forget, there is a maximum of 5GB use. After that it will cost you a small fortune. Better 3G with 12GB, than 5G with only 5GB allowance. Think about it.
